Any suggestions? I've hit it for about a week every day with penetrating oil. First with T9, then with WD40, then with PB Blaster. I've also used a propane torch on the outer member to try to get it to expand. I've had absolutely no luck. The bolts won't budge. I was thinking my next step may be to drill out the grommets attaching the plastic levers, then use a crescent wrench to try to free the bolts, then find another set of metal levers that I could attach and use in the future as the plastic ones seem too weak.
Whatever the outcome, I will be applying antiseize to the bolts once the issue is resolved.
