Yanmar 4jh engine has a b control panel, what is the proper way to start it up and shut it off?
Mar 22, 2022
78
hunter legend nj
Help
I just purchased a 87 40 ft hunter legend with a yanmar 4jh engine with the B control panel that is the
the control panel has a toggle switch an a yanmar key switch does the toggle switch brink on the glow plugs
or does the key switch bring on the glow plugs also there is a brass pull knob just in side the companion way does the stop the engine being a diesel engine doe it shut off the fuel
Need help person i bought it from has pass away
Rick
Mar 22, 2022
78
hunter legend nj
No it has a tachometer a toggle switch a key start an the area that would be the stop bottom has a plastic plug put in it an i think it was a row of indicator light
Nov 6, 2006
10,244
I don’t think that it has glow plugs. It would usually be started by opening the throttle a little and cranking . The stop is the pull knob in the stairs. The toggle switch is to check the bulbs in the alarm lights in the panel and switch on the tachometer lamp. Some B panels had a push button start where you turned on the key and then pushed the button to crank it.
Jan 7, 2011
5,999
Oday 322 East Chicago, IN
A photo would really help…
but my Yanmar 2GM20F, from the same era, has a key and a push button. Turn the key on and heat the alarm tone. Give it some throttle and push the button (hold it in) as the engine cranks over and starts. Don’t crank too long if she doesn’t fire Or risk potential hydro lock.
Mine also has a T-handle that is connected to the fuel cut-off on the engine…pull that handle up to stop the motor.
Likes: Ward H
Dec 25, 2000
6,059
Yes, a photo would help. However, our 4JH2-TE does not have glow plugs. The toggles on our panel control panel lights and no push buttons. Just turn the key to start.
Likes: kloudie1
961
Macgregor & Island Packet VENTURE 25 & IP-38 NORTH EAST, MD
Look like this one? The toggle switch is for panel illumination and panel lamp check. The red knob to the left is is the engine stop, by pulling it out. Yanmar 4JH’s do not have glow plugs.
5,999
It looks like the key is marked:
Stop (not very legible).
Off
Run
Start
So, I would turn key to Start to fire it up, once running, let go of the key and it rests at the Run position.
I assume to stop the engine, turn the key to STOP. Once engine dies, turn key to Off and remove it.
BUT…I have no idea what the big red ejection seat button does…maybe the STOP setting on the ignition switch was erased intentionally because it doesn’t work (a solenoid I think) and they replaced it with a manual engine kill cable like my 2GM20 has….if so, pull the red thing to kill the engine.
The toggle switch is for the panel illumination. I assume the TEST setting turns on the idiot lights to make sure the bulbs work.
Mar 22, 2022
78
hunter legend nj
Yes that is it but no big red button do i turn the key to the left to ( glow for 15 seconds then turn to far right to start an leave it back to mid right for run ??? ( then turn to off an pull the fuel shut off just in side the companion way by the top step till it come to a complete stop ????
Jan 7, 2011
5,999
Sorry, I thought that was your photo Rick.
As someone else said, I don’t think that Yanmars have glow plugs. And if you ignition is as I stated above, there is no glow plug setting.
Set your throttle maybe 50%, turn key to START, engine turns over and starts. Release key to RUN.
Turn key to STOP (you might have to hold it a few seconds until engine dies). Return key to OFF and remove key.
Try that and see.
Mar 22, 2022
78
hunter legend nj
Hi Greg
Mine does not have a stop button but it does have a plunger to pull in the companion way that
i thing shut off the fuel to it no stop button
Jan 7, 2011
5,999
Hi Greg
ok…got it.
Are you having trouble starting the engine?
Mar 22, 2022
78
hunter legend nj
ok…got it.
No she started good an ran smooth during purchase test sail in May
But the pass owner passed a way shortly after selling her to me
an she setting at white rock marina in Md a 100 miles away
So have no one to ask question to
But thanks Greg you been very helpful
Rick
