I am repairing a swing keel centerboard on a P14 Paceship. The original had a plastic spacer in the centerboard hole , which the 3/8 inch pivot bolt went through. The plastic spacer went through the swing keel centerboard, acting like a bearing over the pivot bolt. I need a replacement plastic spacer. The original spacer is very worn and appears to be 1 1/2 length, 7/8 od and just over 3/8 to accept the 3/8 pivot bolt .
Looking online, I see some LDPE and HDPE polyethene, which say they dont swell in water so thats a possibility.
Any suggestions on what type of spacer material that would hold up to boating environment? Thanks
I added a picture below. This is what I found when I dropped the swing keel centerboard. The black spacer fits in the centerboard hole. The long 3/8 bolt pivots in the black spacer. Its unclear if that spacer, which appearently was acting as a bearing, was fixed in the centerboard hole or if it was lose in the hole. Over the years the black plastic roller wore and also elongated the hole in the centerboard. The plan is to repair the elongated hole with epoxy and fiberglass cloth and then drill in a new plastic spacer bearing, which the 3/8 bolt will travel through.
