No need to bond the Marine Grade Bronze valves inside the boat to reduce Galvanic Corrosion.I presume if they are all bonded ?
But if makes you happy go for it. If you do and test it bonded, it will show you Zinc potential.
As long as your Shaft Zinc in grounded to the engine or Battery, the Zinc will protect the Bronze Valves.
If you lose your Zinc, then Galvanic Corrosion starts on the Bronze and your Stainless Steel shaft.
Of course there is alway metal corrosion in salt water. Thus the Alloy Marine Bronze, which has very low corrosion rate.
Jim...
