Seeking advice from any chemists, bottom paint related
Nov 12, 2009
279
J/ 32 NCYC, Western Lake Erie
We're in the process of applying new SN-1 ePaint over existing SN-1. The roller was lifting the old ePaint so badly that we switched to using a brush. Brushing does not lift the original layer but the new paint is so thick, and it was so warm on Sunday, that the paint was not flowing or leveling.
Their web site SDS says the appropriate thinner is aromatic and aliphatic hydrocarbon. Any suggestions as to what would work as a generic thinner?
I've been trying to reach epaint the last 2 days to find out about their thinners to no avail. I'm not too excited about waiting any longer to maybe hear back from ePaint, and then waiting another 2 or 3 days for their thinner to arrive since I only need to thin about a quart of their paint.
Thanks for any insight or advice.
Jul 7, 2004
8,536
Hunter 30T Cheney, KS
If it's lifting the old paint you may have an incompatible paint layer underneath that layer. That would suck.
Mar 26, 2011
3,988
Corsair F-24 MK I Deale, MD
Call e-paint. They have some weird compatibility and adhesion characteristics (I have used it).
JamesG161
Feb 14, 2014
8,033
Hunter 430 Waveland, MS
Mineral spirits
:plus::plus:
Add small paint amount into a container and add Mineral Spirts[MS] ounce by ounce , mixing with a small brush.
Keep track of the Volumes of Paint to MS ratio.
Once you know your thinning ratio, Mix larger volume and paint.
Jim...
PS: I would test a small area and let dry overnight. See if it does the expected job.
Nov 12, 2009
279
:plus::plus:
Jim...
Sounds like the best suggestion so far, especially since the ePaint rep I've been trying to call hasn't answered the phone in 3 days. Thanks.
JamesG161
Feb 14, 2014
8,033
Per @sail sfbay post info
aromatic = Xylene. [not fun stuff and hard to find]
aliphatic hydrocarbon = Mineral Spirts [ not too toxic, but flammable and available]
But the ratio of their mix is unknown.
Thus finding the right mix of MS Thinner to Paint, that fits your applicator tool and outside Temperature.
Lets us know how your painting turns out.
Jim...
Nov 12, 2009
279
I wouldn't wish ePaint on an enemy. Hope this works out.
Since we started using ePaint we have had virtually no growth on the bottom, and have not had the bottom power washed when we haul out in the fall. Adhesion is the big issue! I think everyone at our club that has tried ePaint has had problems getting it to stay on, some adhesion problems much worse than others.
We have been willing to live with the small area failures in the past because the bottom comes out almost as clean in the fall as it went in in the spring. We're hoping that maybe thinning the paint and brushing it on might alleviate some of the application issues we're having this spring.
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
This sounds like a real good reason not to use it. Wondering why you did.
JamesG161
Feb 14, 2014
8,033
My guess it is called E-Paint as E = Environmental Friendly in Fresh water Lake Erie.
But that issue of adhesion is not E friendly, as it takes Ablative paint idea to an extreme by dropping the paint scale into Lake Erie.
Best of Luck @Sailor Sue
Jim...
279
Jim...
Jim, I finally heard back from ePaint. Xylene will work as a thinner, but will probably flash off a bit quicker than their proprietary thinner. Now to do a little sample test. Thanks again.
JamesG161
Feb 14, 2014
8,033
will probably flash off a bit quicker [Xylene]
And it is like, Benzene, a known carcinogen.
Also aromatic means "Flash off" . Think of Aroma of perfumes that "Flashes off" from skin absorption.
I strongly urge, for your Safety, use Mineral Spirts. Xylene is extremely flammable and you need a respirator to use it.
Jim...
PS: I am a Chemical Engineer with a Major in Chemistry.
Jim...
:plus:
And I am a Ph.D. chemist. Also you opened with ..
Those are kind of on opposites ends of the hydrocarbon scale. Aromatics have benzene rings ... aliphatic are straight chain... Gasoline is an example of a mixture of the two...
I'm going to guess hexane will work but honestly any organic solvent that seems to thin will probably work. Mineral spirits (from Lowes) is the safest. Be mindful of the flashpoints (spontaneous combustion) of the solvents you are using. Mineral spirits is 100F. Xylene is ~90F. Both are high enough that if you work with small amounts in a well ventalated space you are probably safe from the on looker who lights up a smoke.
You could do a small test with some commercail paint thinner. They sell this at Lowes. I'm going to guess it is made in the same factory as your epaint thinner.
279
Thanks to JamesG and rgranger - that is the kind of information I was hoping for. Tomorrow, based on your responses, I will try thinning a small amount of paint with mineral spirits. If that doesn't work I'll try a bit of xylene.
