I need to build a new wood mast step for our C&C. The original is a rectangular solid piece of oak about 2.5 inches thick which is bolted to the hull.
I have a friend who has the same boat and he made his from 3 pieces of oak, laminated together.
I assume each section waa done with the grain perpendicular to each other.
Which is better ? Solid piece of oak covered in thinned epoxy or 3 thinner pieces of oak epoxied on top of each other ?
I would assume that the thick wood piece is stronger but the laminated one would be more less likely to warp.
The laminated one would be cheaper but in this case I would rather not deal with this ever again.
