Hi. I have Hunter 49, she has done many miles (Over 100k) I live on board and recently picked up a load of fuel (Aprox 500L) and shortly (20min) after the engine (4JH4-HTE) exhibited signs of fuel starvation and stopped. I hadnt changed filters on a regular bases, but the last time this happened (4 years ago) I simply replaced the Racor 20s filter which was long over due and all was fine.
This time that hasn't worked. The fuel I took on came from a reputable source, its filtered, and they use it in a number of Lagoon charter boats, so I assume its good. Having now used up a couple more Racor filters (30P was all they had) and also replaced the Yanmar filter on the side of the engine, and still the same result, I'm coming to the conclusion that the act of taking on a large amount of fuel from a station type pump has stirred up sludge at the bottom of the tank.
The tank shaped like a single bed mattress (similar size) and even if I cut one whole to get my arm in there, the baffles and size make it extremely difficult to clean properly. I would also want to be 100% sure this is the issue before cutting wholes and dropping debris inside to then figure out how to seal it again.
So im pondering trying to build some sort of fuel polishing, simply run a small fuel pump (the one on the genset seems to work) to run the fuel through the Racor and back to the tank either via the return line or via the fuel sender gauge whole. Then backwash the Racor, (disposing of the fuel) and repeat that step, till the Racor has recycled a couple of tank loads.
So anyone ever cleaned one of these tanks ?
Anyone had any other problems, other than clogged filters due to sludge in the tank resulting in the apparent starvation of fuel ?
Note if you have this problem that I have, pumping the fuel prime plunger on the top of the yanmar fuel filter will breath new life into the Yanmar and save you being caught with no motor at the wrong time, but be quick and show someone else how to do it.
