Semco Teak Sealer - progress photos
Feb 28, 2022
213
Catalina 22 12482 Champaign-Urbana, IL
Got recommended the Semco Teak Sealer on this forum, so thought I'd post progress photos. I used Semco on other wood on the boat and have photos of that if folks are interested.
During Application:
Still Wet:
Dry after second coat:
Installed after fully dried:
Apr 5, 2009
3,193
I have been using this for the past three years and it stays great with a quick reapplication with a rag in the spring and fall. I used their two-part cleaner before applying the first coat which removed all of the old finish and black grunge in the grain.
Feb 28, 2022
213
I should have done their cleaner first. I sanded the boards down, but I feel like they would have benefited from a cleaning. Either way, it’s an improvement.
Jul 26, 2009
291
Looks good! Which version of did you use (clear, natural, honeytone, etc)
Apr 5, 2009
3,193
I use the honeytone.
Before any work on sprit
After 2-part clean and light sand
after Semco
The thing I like best about it is that it doesn't look or feel like it is finished. It is the closest thing I have found to bare, fresh teak. Oh, and that it holds up will for at least 6-mounts. Last fall I did not get a chance to do my fall recoat and there are a couple of spots that will need a few minutes of sanding but that is not bad for one full year since the last coat.
3,002
Beneteau 343 Slidell, LA
Looking good!
I use Semco clear tone on my cockpit teak seating surfaces. In fact, it’s on my list of things to do; Clean & apply 2-3 coats.
Feb 28, 2022
213
That one is the step right inside the boat. It came with it. It is some kind of plywood, but I Semco’d it too.
Feb 9, 2020
12
Catalina 22 Louisville Sailing Club
Looks good. I hope you will do another shot with it to show how it held up at the end of the season.
