Hello,
Continuing the renovation of my Bristol 24. I got the old floor out as it was starting to rot from the bottom up. They didn't seal the backside at time of manufacture, just painted the top. Over the years, minimal water in the bilge has done-in the floor and last season it flexed and bowed with every step.
The plywood is 3/4" thick! Marine plywood for replacement is over $220 a sheet.
Any thoughts, recommendations, or ideas on whether or not I can use high grade, standard plywood and coat in epoxy? Would this be sturdy enough and stand the test of time? I don't want to do this again in a few years. Ripping out all the cabinetry and benches to get to the floor and keep them in shape to go back in was not an easy or quick task.
Thanks!
Pete
Thanks!
Pete
