- Aug 10, 2010
- 117
Well, I think I have officially joined the club. Apparently a club that seems to be reserved more for H30 owners, but nonetheless, it's a club with many members. We have a 1982 H36, owned previously by my folks. The old man made many upgrades and took tremendous care of this vessel. One aspect of that it seems to have experienced the end of it's lifespan.
The sub-sole mast support post of the H36 apparently was different then the I-Beam approach used on the H30s. In our case, it was a cast-iron tube, encapsulated (I think) in fiberglass on the bottom, and bolted to the underside of the cabin sole on top with a plate welded to it. Many years ago my father realized the post was rusting due to a water leak, so he wrapped the post in fiberglass and filled it with resin. He seemed to think it would give him some time...well 30 years later it seems to have started to fail. My "should I be concerned meter" is at about a 9.9 out of 10 at the moment after reviewing current pictures and seeing what appears to be buckling and compression failure of the post and resin concoction. I have searched the forums and read many tales, mostly concerning H30's. I realize the fix is similar regardless of specific boat type. But whilst I search for a boatyard with space that I can put her on the hard, remove the mast and get to work, anyone have any H36 specific tales to share?
My present plan, is to remove mast (yes I've seen a post or two about fixing this without un-stepping the pole, but I actually have a few other things that could benefit from having a mast on the ground so I plan to take this more costly approach), remove the trim/casing around the wooden post if nothing else to inspect the wooden post between the cabin top and cabin sole, and then remove/replace the failed/rusted iron post. My initial thought was to replace it with an aluminum or SS item, but reading Diana's posts from John C II, made me contemplate a more intricate fix of structural stringers, etc. But I'm not sure how realistic that is on a H36.
So until then, what have previous H36 owners done in this situation, if anything? I apologize for the pictures, I will gather more tomorrow, but for now I can see what appears to be a bucking of the iron/fiberglass....which may explain the "wrinkling' I've recently noticed on the cabin top just aft of the mast...Thanks!
