Hunter holding tank
May 7, 2012
19
Hunter 30T 1 GA
I have a1993 Hunter 30T. I may have to replace my holding tank. I have looked online for what size it is . I have found water ,37 gal, and fuel ,18 gal, capacities but cannot find holding tank capacity. Does anyone know what is or where I can find this info
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
I use to have the same boat. I replaced my tank with a custom tank. I think the original was 15 gal. I think I installed a 22 gal. I no longer have any of the paperwork on the tank I purchased.
Dec 2, 1997
9,011
- - LIttle Rock
If it's a rectangular tank, it's easy to determine the size: L x W x H in inches, divide by 231 (cu in/gal). Because you're measuring outside dimensions and because not every cu milimeter of space is useable, get a squirrely number with a decimal point. For instance something like 16.4327. 90% rounded up to the nearest whole number--in this case 15--is the usable capacity of the tank.
Ronco Plastics Ronco Plastics marine Tanks is your best source for a tank. They make TOP quality thick-walled water and waste tanks for a very reasonable price and have more than 400 shapes and sizes, over 100 of which are non-rectangular, and they install fittings in the sizes and locations specified by the customer when they make the tank. There are retailers who sell Ronco tanks, but Ronco sells direct for a much lower price...and they're great to work with.
When looking at drawings it's important to know that there is no top or bottom until the fittings go in, and YOU decide where they go. So rotate, flip in any orientation to find the tank that fit your space.
Boat builders rarely if ever pick the best --or even passibly good--location for a holding tank, often putting 'em in inaccessible locations, resulting in nightmare hose runs and always just put all the fittings on one end...which is rarely the best place for 'em because putting 'em in a vertical wall loses capacity. I'll be glad to help you find a good location for it and the best fittings locations.
As for capacity...I see you're in GA. If you're on Lake Lanier (no discharge), 14 gal is a bit small if you use the boat much unless you want to pump out every week. Otoh, that's a decent size if you're on the coast and have easy access to open sea at least 3 miles offshore where you can dump the tank.
--Peggie
Likes: ggrizzard
Hunter 34 Herrington South, MD
I replaced my HT with a custom made - just look at their offerings and measure for your input and output. But importantly, since I sail only on the Chesapeake Bay, i realized that I would never need a thru hull for waste, nor the hand pump, etc. Ended up with a much cleaner set up.
Likes: ggrizzard
Feb 28, 2022
3
Hunter 28 Rochester
As others have stated measure then buy what fits. I have had this unpleasant job on my H28. 1992. The aluminum tank split a corroded weld in July and I was rewarded with a very foul cleanup. Please note the old tank would not come out through the Lazerette hatch nor would the new one go in. I had to cut an opening through the plywood frame from the after birth into the lazerette.. After the mess was fixed I framed the cut out with teak and put it back in place.
Jul 7, 2004
8,502
Hunter 30T Cheney, KS
In the H30T it will come right out. You may have make modifications to get larger tank in.
FYI, I use the SCAD tank monitor on mine.
Apr 24, 2013
2
Hunter 30 Trois-Rivieres
In my HUNTER 30T 1994, I change the original aluminium 15 gallons for a plastic 20 gallons.
It's a TRIONIC Corp, Model: SP-2020.
There is an article about that on this site: Home/Owner resources/Hunter model information center/Hunter 30 88-94/Owner mods.
I remorve the wood frame and replace it by the top to avoid cutting the bulkhead.
Likes: Justin_NSA
