Need to Replace a Reading Light, or its Switch
Sep 22, 2021
307
Hunter 41AC 0 Portland, OR
One of the reading lights in the forward cabin of our 2007 41DS has a switch that is intermittent. I looked at the DigiKey and Mouser sites and couldn't find a panel mount rocker switch as thin as this one is. Eventually, I'll probably replace the lights with LED light but I'm not ready to do that yet.
Does someone have one of these sitting around that they'd be willing to sell? Or, does anyone have a tip about where to look for an item like this?
Tater
Oct 26, 2021
198
Hunter 170 Lake Logan Martin AL
I am a day sailor and don't know much about larger boats. I do know a little about lighting.
If this light is 12 volts there is a bulb available for RV/marine use by FEIT Electric. Home Depot sells them. They are made like any A19 bulb and fit a standard socket. That said, finding a lamp should be easy. I use these at home for emergency lighting. They are on continuous and are equivalent to 60 watts.
Feit Electric 60-Watt Equivalent Warm White (3000K) A19 LED 12-Volt RV/Marine Light Bulb BPA800/830/LED-12 - The Home Depot
Likes: ggrizzard
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
You know, there's a possibility you can take that switch apart, clean the contacts, and put it back together. I've done this to similar switches. I'm surprised you can't find one on Mouser or Digikey, though.
Likes: ggrizzard
Oct 29, 2016
1,929
Hunter 41 DS Port Huron
Have a look here, this is the company who supplied the original fixtures
And another fantastic source of information right here on SBO
I changed all the bulbs out to LED same fixture just different bulbs I believe it was under $30 to do the changeout
Likes: jviss
Nov 6, 2006
10,244
Sometimes, a squirt of silicone spray and exercising the switch can clean it up.
Sep 22, 2021
307
It turns out that the terminals were loose in the switch housing so they would move around, interrupting the circuit, when the switch was jostled. I have it working for now - I wrapped some masking tape around the end of the housing and drizzled in some epoxy to hold the terminals securely. I also cleaned the contacts while I had it apart and adjusted the spring leaf to apply more force to the contacts when closed. So far, it seems to be working.
jviss
Feb 5, 2004
7,090
I love when that happens! Nice job.
Likes: ggrizzard
