Hunter 49/50 alternator wiring
Jan 4, 2019
62
Hunter 50 Halifax & Martinique
I had to take out my alternator to change the impeller, not having done the Boas Fix yet. When putting the alternator back on there was a grey wire with a male connection that I didn’t notice earlier. Does it connect to anything?
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
That's probably the field wire, and there should be a receptacle for it on the back of the alternator.
Jan 4, 2019
62
The 4 wires that are attached to the alternator use a clip or a bolt to secure them. This grey wire has only a clip on connector that doesn’t seem to have a home.
Aug 18, 2018
151
Hunter 410 MDR
Are you're talking about the short wire with a receptacle attached thats on the alternater? I have that and it goes to nothing, I believe, but could be very wrong, that it's a ground wire, but our alternaters are already grounded to the engine. So not needed.
In my case that's how its always been working.
Feb 11, 2019
22
Hunter 29.5 Bristol, PA
Can I ask what the Boas Fix is?
Jan 4, 2019
62
Art Boas posted a new water pump instal on front of the engine to replace the existing pump with the difficult to access impeller.
May 1, 2011
5,272
Pearson 37 Lusby MD
I can't find the file in downloads, but here's an old discussion:
Dec 15, 2019
162
Hunter 49 San Diego
I recently replaced the turbocharger on my 4jh4 HTE and stumbled onto a short cut you might be interested in for changing the impeller. Removing the three bolts and the two hose clamps on the exhaust manifold allows great access to the raw water pump. It is relatively easy to reach in and remove the bolts and impeller. I think it’s less hassle than removing the alternator. Turns out, the old turbo was fine as was the exhaust elbow, which I found out was bronze and bullet proof. I went ahead and replaced the turbo anyway since I had many hours invested in taking everything apart to gain access. I was also worried because I didn't hear a turbo whine when throttling up. I learned later that low pressure turbos don't always emit a distinct whine like high pressure turbos do. The new turbo sounds exactly like the old one. This information might be helpful for Hunter 49/50 owners with over 1000 hours on their engine who are contemplating replacing their turbocharger as scheduled maintenance.
Likes: Daze
Jun 1, 2009
1,860
Hunter 49 toronto
Ok, try to do this when your boat is in the middle of a channel, and you have 15 knots of wind on the beam.
The modification permits you to change the impeller in less than 10 minutes with zero stress.
Btw, I know of some folks that tried the “work around” you are suggesting. It was just impossible while cruising with a hot engine below your chest.
This mod costs $200, and takes less than a day. It’s illogical not to do it, and is the ONLY reason I was able to keep my boat. I cruise to the 1000 islands, and there is an overnight passage through dangerous shoals. I refused to do this until I had a way to keep myself safe .
Likes: JR19454
