They replace the existing adjusters. I measured my adjusters and they are within the range of these. Mine have 17 holes and these have 7 so fine adjustment isn't possible. I can live with that over being thrown to the cockpit floor and attacked by the mast. If you go to the link at Duckworks there is a hole-to-hole specification.Just a question about those shroud levers.....
Great. Thanks for the info. By the way Tater... I grew up just down the road from Logan Martin Lake in Talladega. Nice area.They replace the existing adjusters. I measured my adjusters and they are within the range of these. Mine have 17 holes and these have 7 so fine adjustment isn't possible. I can live with that over being thrown to the cockpit floor and attacked by the mast. If you go to the link at Duckworks there is a hole-to-hole specification.
Stickinthemud may have more info.
Like a kid with birthday money, I have a tracking number!
I know Talladega well.Great. Thanks for the info. By the way Tater... I grew up just down the road from Logan Martin Lake in Talladega. Nice area.
Guntersville is a great lake to sail in. Much more open water and a lot more wind.I know Talladega well.
The area near the dam has plenty of open water. I want to try Guntersville soon.
I spent a few years in the Air Force. Some of that time was at school on a Navy Base. That was culture shock on steroids. It was like someone had the job of renaming common items to fit a maritime culture.If my experience is any indicator, that additional length will be enough to get the base of the mast inserted at the tabernacle.
I had to laugh at your "who names this stuff" comment. Just yesterday, I was musing on the number of terms the apply to boats and only to boats:.......
Great. Thanks for the info. It looks like installing them with the existing shrouds shouldn't be a problem. In my case, I am ordering new standing rigging and wanted to make sure the standard length stays would fit the levers put in place by the previous owner. Those levers do make stepping the mast very easy.Jeremy, I have the adjusters.
In my case, position 2 adds about 1.75 inches when open. I'll install and test. If this isn't optimal, I should be able to incline the mast partially and set in the tabernacle. (Who names this stuff?)
View attachment 202275View attachment 202276
