Yes indeed. That's how my SSB is run. I've not seen it done any other way actually, the root of my question. But the OP doesn't have a backstay. So I've no idea how you'd run an appropriate length antenna without that.
Yachts without rigging would usually use a vertical antenna. Again, most verticals are about 23' tall. So it is possible the OP might have some kind of connector either on the transom or possible on the stern near the pushpit/railing. It would probably be some kind of screw on mount that are found on cars.
I never realized the length began at the tuner. I'd always thought it started where it connected to the backstay antenna... How would shielding around the segment from the tuner to the backstay affect antenna performance? Any ideas on that?
Shielding would prevent the most active part of the antenna from radiating. The highest concentration of radiated power is at that point, the output port on the tuner. One can place a fluorescent bulb at that point and it will glow. That is how, in the old days, hams would tune their radios, for maximum brightness. The white cable that goes from the tuner to the base of the wire/backstay/vertical is not coax, but GTO-15, which has the same diameter as RG-8X/RG-58/LMR-240. It could be mistaken for coax by appearance.
That would make more sense. As I look back, I don't see a VHF antenna.
It's fun to think about all this for sure...
dj
Sometimes this is more fun than sailing. At least more challenging in ways.
