Here is how the dimming worked on the previous lights;I replaced the lights in my 49 as instructed above with the SBO LED replacements. I trimmed the flange with a hand saw (coping saw) and smoothed the edges with a wood file. The results are spectacular. I now have bright, high quality, natural looking light. The originals were awful. I replaced the dimmer with just an on/off switch. If I want less light, I’ll use one or more of the spot lights, which I also switched over to LED by retrofitting the originals with an LED bulb.
There was a third wire from the Ccfl fixtures that all connected in parallel, and went back to the dimmer.
The other 2 lights on the fixture were v+ and gnd.
The third line was a duty cycle modulated (pwm) signal that controlled brightness
It’s easy to control brightness on these fixtures.
Just connect an LED dimmer into the v+
feed.
Wire the 12v+ to the dimmer input, and the output to the led fixtures
You can get a nice unit from Lumitec that has a mountable remote disc.
