Have any of you H34 owners had to replace your fuel tank? Were you able to remove it through the lazarette opening or did you have to go through the aft cabin?
What did you use for a replacement tank? Custom fab aluminum or plastic?
Do you happen to know of auppliers in Canada? I have been trying to track down a small (but smellable) leak and ended up using a UV fluorescent dye and small UV flashlight. Looks like there is a band of diesel along the base of my tank. Photo of the band and positive reference photo of the fuel take off line for the diesel stove. Same fluorescence. Nothing leaking at the fittings so methinks my tank has lived its life
