The Anchor Locker has an above water drain, but the bottom of that Locker is solid.do some fiberglass repair of the bow above the waterline but below the anchor locker.
Thanks yes the access panel to the windlass comes off easily. I need to get the vertical piece that covers the bow below the windlass access panel to repair some fiberglass damage in the bow.Reply to OP: The bottom panel is just held with 4 woodscrews and gives access to windlass and surrounding deck area from inside. My H38:is hull 106 build in 2004 but I found construction differences between hulls.
1 minute agoIn your owner's manual, behind the wood panel is the Anchor Locker.
Pictures of your repair area would be helpful.
Jim...
Ouch! Pat1 minute ago
Add bookmark
#6
Jim...
View attachment 200234- Thanks - the area to be repaired is in the bow above the water line and below the anchor locker drain. A mooring ball damaged it in a storm. It is covered in the attached picture with black tape
