Silly question I suppose... I just purchased a new to me 2003 Catalina 36 mkII. How do I tell (without measuring) if I have the Tall Rig or Standard Rig? Is it coded in the hull ID#? The manual, of course has specs for both versions.
He wants to know how to answer the question without measuring. A tall rig by definition would have a taller mast.Congratulations on your new sailboat!!
Interesting question..........a few options to verify:..........etc.
Fast and easy ...........take a photo of your sailboat mast from a distance then scale its height from the deck to the top vs. a known length in the same photo. Then compare it to the tall vs. standard rig "I" spec for each..............How do I tell (without measuring) if I have the Tall Rig or Standard Rig?.......
There you go! That sounds like the easiest thing to do so far. Ultimately I think best to run a tape up the mast. -Thanks!I think that the boom of a tall rig is 13 foot and the standard rig is only 12 foot - that's the E dimension.
I certainly have !!!! Thanks for all your help. Stay tuned for more ridiculous questions in the future! -EdSo many options for "Measurephobia" challenged owners.
The use of Geometry to identify a height plays into the prophesy of HS Math teachers... "You will need this some day!"
Lets hope that @EdWard3 has found at least one solution that will serve his needs. I am in favor of the "Bridge Contact" method. Kind of the way my cat decides to wander into a space. If the whiskers touch the hips cannot follow.
Not every method is without risks... Just have someone film the event. It might spice up our winter days.
Which one is REALLY priceless?I consider the one in my tool box priceless.
I took the without measuring to mean, I do not have a 100' tape measure to run up the mast. Even a fat max tape has distance limits.Which one is REALLY priceless?![]()
So, @EdWard3 , which rig do you have ... so we all can tell you why you got the wrong one![]()
