Hi just pulled my boat out for bottom maintenance and hoping to solve a huge problem. Since I've had her when she's underway under a heavy load there is a ton of smoke, fuel discharging. Had injectors checked and they are fine. My propeller is plastic and has an extension that allows it room to turn. I think that is the problem. So, I'm wondering what propellors do you use with a modified engine and no, I can not afford a shaft extension...I'm still wrapping my head around that it's plastic.... I can supply a pic tomorrow if you want to see it.
Thanks.
Thanks.
