Inherited a slip with pulley system attached on rear piling of slip, each side.
This system is new to me, however it does a great job keeping the boat( 1987 Cat 22 SK ) centered in the slip.
Replaced the pulleys and hey hooks, but not sure what is attached as a weight to this system.
Local slip residents offered up replacement weight as a 34lb. concrete block with 5/8 line.
Assume there will need to be a chaffing proof attachment to the concrete block.
Concerned if the weight of these blocks is not established first, I may end up with boat cleats failing.
These pulley lines are crisscrossed over the Aft Transom and attached to the boat accordingly.
Guidance from experienced sailors with this system is appreciated.
