The attached photo belongs to a plate located in the last compartment of the aft cabin. This compartment is located right after the compartment that provides access to the engine transmission and shaft, under the seat cushions in a 1986 Hunter 28.5. There is water leaking through the plate in the area I circled and I'm not sure if I should loose these bolts and remove the plate since I can't find this section in the boat manual and I'm not sure what is underneath or what are those bolts holding below. Any advise will be appreciated.
