I have a 2005 Hunter 41 DS. My forward head has a Jabsco macerator #37045-7001, my aft head has a Jabsco #37010-1090. My forward head has a discharge to the waste tank and fresh water in to the head, that's it, simple and works fine.
My aft head has on the macerator a discharge to the waste tank, fresh water in, water out to the head. I think this is the wrong macerator. Fresh water will only go to the bowl when the macerator runs. So the water only doesn't work.
I did find behind the panel a capped off water line and when I connected it to the bowl everything works as it should.
If I just capped off the water in and water out on the macerator, would I burn it up? Should I loop it together? Should I buy another macerator to match the forward head?
