Last weekend I finished getting the rotten plywood core out of the section I am working on. While there is more to remove forward of this work area, I am limiting this job to just the area 2 foot forward and 2 foot aft of the port chain plates. This area is an "A" issue on my survey.
The existing fiberglass top and bottom will be used again in this project, while the water rotten plywood core with be replaced with small (5" x 5" max) pieces of plywood. The area is about 5 feet long by about 8-10 inches wide.
I have West Systems epoxy and extra slow hardener. I want as long of a working time as I can get. With the temperatures above 70F the extra slow seems to be correct. I also have 6 ounce cloth, although I don't think I'm going to use much if any. I have 6 ounce 2" cloth tape. The fillers I have are 406 and 407.
What I don't want do is get caught with too much to be done when the epoxy starts kicking off. This is why I'm thinking about my procedure so much.
Cut and dry fit every piece and making sure that chain plate holes line up correctly. (Chain plate holes should be a bit oversized so that I can epoxy fill the gap. Mark the pieces so I know where each goes.
4-6 Piece Batch
Repeat the 4-6 batch process until I get the entire 5 foot section done this far. This will leave the entire top area of plywood pieces without any epoxy on them.
Cover the area one cut out piece at a time
The deck sandwich top was taken off in 5 pieces, ranging from about 8 inches to a foot in length. Working with a single piece
Join the edges
Once the sandwich has cured I'll bevel the edges an inch on each side and cover it with 2" tape. That should be a big enough bevel for the 1/8" cut. It should be simple enough, maybe a one inch wide piece covered by a two inch wide piece. Covered with nylon fabric (Ripstop Nylon Fabric from Joann Fabric) as peel ply. That should work right? It's 1/2 to 1/10 the price of "peel ply / release film" and 100% nylon.
I'm sure some people may be able to finish this in 4-6 hours. But I think I am going to do one stage per day. Saturday, the plywood. Sunday the lids, Monday (holiday) the edges.
After that I think I'm going to take a couple weeks to see how things look and decide how to gelcoat it. Is there problem with waiting a while (weeks... a month... till spring?) without a gelcoat on it?
Thanks everyone!
-Rick
4-6 Piece Batch
- Start with enough pieces to go maybe a foot or less along the length of the work area, about 4-6 pieces.
- I think I should wet these 6 pieces along the edges and the bottom face until it stops soaking up the epoxy. I want to leave the top uncoated until later.
- After the plywood is soak enough epoxy, I will wet out the bottom fiberglass of the deck sandwich
- Judiciously spread thickened epoxy (mayonnaise consistency with 406) over the bottom of plywood pieces
- Position the pieces in their appropriate spot and weight them down with say bricks
- Fill edge gaps with thickened epoxy
- Wet out the top of the plywood until it wont take any more epoxy
- Wet out the sandwich top piece
- Judiciously spread thickened epoxy (mayonnaise to peanut butter consistency with 406) over the top of plywood pieces
- Position the sandwich top piece and weight it down.
Join the edges
Thanks everyone!
-Rick
