Hunter 386 cabin lighting replacement
Sep 11, 2019
170
Hunter 386 Lake St. Clair
Hey Guys, looking at swapping out our cabin lights with led. Question 1, how do I get access to bulb ( I'm sure these things are getting brittle after 20 years). Question 2, any ideas regarding replacement? Thanks,
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
A photo of the lights and their inside and outside dimensions would help. Do they have an integral switch? Do they have a ring you can pop off to get access to the light? You might be able to match the light and buy them from this site SailboatOwners.com search .
170
Sorry for the later reply, just got back to the boat yesterday. Attached is a picture of the light in question.
Jul 29, 2004
413
Hunter 340 Lake Lanier, GA
Sorry for the later reply, just got back to the boat yesterday. Attached is a picture of the light in question.View attachment 196662
Gary, the white bezel snaps on and off the base, using a small screwdriver or fingernails to pry it loose. Be careful though as the glass lens is loose in the bezel and easy to drop. I believe the LED bulb is a side pin G4. I bought mine at marinebeam.com about 5 years ago. They are also available on the store site here. edited: I had posted a bad link see next post for correct link. Interesting, the corresponding part for the H340 is white, not beige.
JamesG161
Feb 14, 2014
8,032
Hunter 430 Waveland, MS
You might work your light switch on/off. Mine sometimes do not work with little use.
Jim...
