Hi folks! I have a 2000 Hunter 240 I bought after MANY years of neglect and sitting on the trailer. I'm down to replacing the last few bits to get her back on the water where she belongs. However, I replaced the battery yesterday and nothing is working. I suspect that the panel, breakers, fuses, and relays have lost the battle with corrosion.
That being said, I have a few questions for the salty sailors here:
1. Should I scrap all of the wire and just re-wire everything?
2. Should I replace the panel and associated switches, fuses, & relays?
3. If a new panel is in order, where would I find the entire assembly? Hunterowners.com doesn't carry it (that I could find) and no specifics are in the manual.
4. Should I rebuild the panel for myself with better rocker switches, fuses, and relays AND re-wire the whole thing?
I know you kind folks will steer me in the right direction. Thanks in advance!
-Cheers
-Cheers
