I overheated my Yanmar 2GM and the exhaust hose started leaking. After replacing the rather old exhaust hose the muffler inlet fitting is leaking when the engine is running. It looks like inlet fitting has become crushed a bit. There is a crack on the fitting that runs inline with the hose starting about 1cm inside the hose.
Is it possible to repair or replace one of these without hauling the boat? I just remember that there is a thru-hull under it but am not familiar with how these systems work. See attached photos.
Cheers!
Cheers!
