So far so good ...
Before:
After:
Primary objectives were to replace the standard pulley with serpentine pulley kit (courtesy Compass Marine), replace all hoses and replace the timing gear case gasket. In the process, I installed ...
New freshwater pump & new seawater pump
New sensors for water temp & oil pressure
New thermostat
New high pressure fuel lines
New chamber components in the cylinder head sockets for injectors
Cleaned & tested injectors
New suction manifold
New regulator lever assembly
New timing shims
Replaced every bolt, nut, washer & screw that I removed
Removed and cleaned the heat exchanger - but it was already free from any obstructions.
Replaced all the gaskets for any components removed.
I didn't replace the hoses to and from the water heater. I could not find any feasible way to pull those hoses thru the confined spaces. I was able to pull out enough excess hose to cut away several inches of beat up ends so they do look much better at least. I haven't installed the vented loop for the exhaust hose, but I have the new hose and loop to install now that I'm in the water. I have to fit a better location for the external regulator outside the engine compartment, but the wiring constrains the reach right now. I also have to make final adjustment to the governor.
Re-assembly went very well, thank you, until I put 2 quarts of oil in the coolant fill the evening before my scheduled launch!
Has anybody done that?!?! I had the fill open and absent-mindedly just started filling ... the 2 fills are pretty much right next to each other.
Just before I started pouring a 3rd quart, I was wondering why the dipstick hadn't started to show any oil yet.
Several hours of draining and flushing and I was good to go. No issues getting from the travel lift to my slip at least. I'll drain it one last time after heating the coolant again.
Before:
After:
New thermostat
New timing shims
Has anybody done that?!?! I had the fill open and absent-mindedly just started filling ... the 2 fills are pretty much right next to each other. Attachments
