Looking for the male NMEA connection to connect a Raymic to the pedestal. The Raymarine model is Ray55. Thanks,
Unlikely that the connector itself will be available. Possibly an extension cable (Raymarine R42124) or old mic (A46051) would allow you to cut off the male end and splice to your handset. Otherwise a new handset will be in order.Looking for the male NMEA connection to connect a Raymic to the pedestal. The Raymarine model is Ray55. Thanks,
Same problem, same boat. Any luck finding a source for the male NMEA connection on the pedestal?Looking for the male NMEA connection to connect a Raymic to the pedestal. The Raymarine model is Ray55. Thanks,
I have the RAYMIC as a remote mic at the pedestal using the connecting cable from a RAY55 VHF. The Mic is a female 5 over 5 pin configuration. The replacement cable Part R42124 is not available in all the usual places. Right now I either need to find some new old stock, cannibalize from a boat graveyard, or find a different manufacturer whose cable works.The Radio has been discontinued. The Raymarine sight shows this link to a cable.
SeaTalkNG cables and accessories Manuals | Raymarine
Download user guides and installation manuals for Raymarine SeaTalkNG cables and accessories.www.raymarine.fi
What fittings do you have? Looking at the mic is it multi pins? Does it fit a radio mic cable, not the SeatalkNG cable?
Note connecting the radio to the network is to provide the DSC connection for 0183 data transfer.
Ellis, the OP, DMclaughlin only made that one post on 1 Jun 2021. He was last seen on the forum on 3 Jun 2021. You may have some luck contacting him if you send him an email. You can do this by clicking on his avatar > Send a Private Message.When I saw DMclaughlin's question for the same boat and radio I have I was hoping he had a solution.
Will do. ThanksEllis, the OP, DMclaughlin only made that one post on 1 Jun 2021. He was last seen on the forum on 3 Jun 2021. You may have some luck contacting him if you send him an email. You can do this by clicking on his avatar > Send a Private Message.
Good luck.
