Behavior of marine batteries
Fredct
Sep 21, 2020
86
Oday 28 Westbrook
Post mortem.
Boat is equipped with a Freedom HF charger/inverter.
The dead battery was the newer one. I swapped and have the old one here at my shop. I may replace the hard-to reach one in the fall.
On shore power, both batteries show 14.2 V, regardless of the selector position. This means that both batteries are being charged at the same time, something that I thought was true all along.
It took about 6 hours for the system to go back to "FUL". When I disconnected shore power. the inverter screen displayed 13.1V and both batteries checked out at 13.1 V on the analog gauge.
I will do a test with the engine on later this week. I strongly suspect that the alternator supplies both batteries at the time time but we shall see.
Thanks for all your help.
Likes: Ward H
This is a big part of your issue. The batteries are being undercharged. Flooded Lead Acid batteries need a charge current of about 14.8 volts. Unfortunately, it appears that your unit is limited in the charging voltages it can offer. By changing the dip switches it can be set at 14.4v which is better than 14.2.
If you don't have the manual, here's a link to it.
Likes: Ward H
Fredct
Sep 21, 2020
86
Oday 28 Westbrook
@dlochner i checked my written notes: analog gauge read 14.4V, not 14.2 . I did see in the manual that I could adjust voltages but this seemed like the right setting for what I have.
All of this reminds me of the old joke about the homeowner calling in the exterminator for rodents. He sets up traps, turns off light and waits. After a few minutes, he goes HaHa, turns the light on and see that traps are full. A fish is flopping near by. Homeowner says, "as soon I get rid of rats, I will work on my humidity problem."
  • Ha
Displays and gauges are great tools. They share the information about the batteries based on the place they are in the circuit. The Inverter display is digital and is better than analog. Mostly because our eyes can fool us into seeing what we want to see. Ever looked at your car gas gauge (Analog display). See it is almost on empty. Then move your head a bit and see that there is a little bit of space between the needle and the red line with the big E. Ah man, I got plenty of gas. I can get another 100 miles before the fill.
Not knowing where the gauges are connected in the circuit, they may hide voltage drops (voltage drop occurs based on cable length and stuff that gets in the way like a switch). It can be difficult to assess the actual voltage status (stored power) of the batteries. This is why we use Digital Volt Meters and test at the battery terminal.
From the last charging period, give the batteries time to settle (discharge plate surface charge). The 13.1V sounds like the readings were taken shortly after you stopped charging the batteries. Not knowing the temp of the batteries and the time from last charge can give you a false sense of the status. We wait for 24hours, then check the battery by contacting the positive terminals and the negative terminals with the DMV leads.
I use this as a "rough guide" for the battery status. The chart is from MaineSails website on Battery Voltage and State of charge (SoC)
SoC​
Chart Resting Voltage​
90%​
12.75V​
80%​
12.50V​
70%​
12.30V​
60%​
12.15V​
50%​
12.05V​
Please be aware that some charts on the internet are for resting voltages. A resting voltage is 12 – 24+ hours of no loads or charging at 77°F. The “at 77°F” is absolutely critical because at temps above 77°F surface charge dissipates more rapidly and at temps below 77°F the surface charge dissipates more slowly.
On shore power, both batteries show 14.2 V (14.4V), regardless of the selector position. This means that both batteries are being charged at the same time, something that I thought was true all along.
Each battery manufacture has a "Charging Profile" to get optimum life from there battery.
For example this is the profile for Lead Acid Batteries manufactured by Trojan.
Table 2
Charger Voltage Settings for Flooded BatteriesSystem Voltage
Charger Voltage Setting12v
Absorption/Bulk Charge14.7
Float Charge13.5
Equalize Charge16.2
The table indicates a 14.7 V Bulk Charge not a 14.4 V charge as being supplied by your Inverter/Charger. One way of thinking about it is the battery is being under fed. It will survive for a while but eventually this will take it's toll on the longevity of the battery.
Not that your inverter is "bad" it is just not supplying the voltage that the batteries need to charge at optimum rate. It means that you will need to replace the battery a bit sooner than other wise "possible". What some boaters seek is the longest life, we can get out of a consumable. We are convinced that this means more $ in the boat or cruising kitty to do more things with the boat. The boat hobby is more sustainable.
Fredct
Sep 21, 2020
86
Oday 28 Westbrook
I want to end this thread but I fear there is another chapter.
1- The "bad" battery now in my shop is a 27M marked Dual-Use. Off the boat for 2 days, it reads 13.1 V using my multimeter, I suppose that's normal since there is no load on it.
2- The battery that i used to repair is a 27M "starting" battery. Higher amps, porous electrodes, not really intended for many deep discharge cycles per a few other threads here.
3- My other battery (#1 or starter) is 27M, likely also dual use, different vintage.
We are going on a 10-day cruise and I do not want trouble (though we will be in well navigated waters). Should I:
a) do nothing, keep an eye on voltage of both batteries and be prudent with power usage.
b) swap house and starter (via the selector switch - no need to move anything - monitor voltages like above)
c) Buy a new deep cycle battery and swap the "state unknown" battery with the new 27M "starting" battery, placing the new deep cycle in the house position.
Thanks for all the help.
Jan 7, 2011
5,944
Oday 322 East Chicago, IN
What are:
1) your charge options daily?
2) how many hours a day between charges?
3) load on the battery when not charging?
if It was me, I think I would be getting a deep cycle marine battery (or 2) for a house bank.
Even that, for 10 days isn’t sufficient without charging options.
Fredct
Sep 21, 2020
86
Oday 28 Westbrook
We will do 5-8 hours of sailing on most days (weather permitting). 3 days at anchor/mooring but not consecutive. Other days: docked so shore power. We will turn on engine each day for 1+ hour which I understand is not enough. My power consumption is minimal but not zero: autopilot (mostly at idle), VHF, some running water, LED lights. No fridge or anything with high draw.
Jan 7, 2011
5,944
If most nights are on shore power, and only 1 night at a time on the hook, you may get away with what you have, but hard to say. No fridge means some saving vs my setup.
I guess worst case scenario, you kill the house battery eventually, but can still start the motor with the backup /starting battery.
Fredct
Sep 21, 2020
86
Oday 28 Westbrook
This was my thought as well. Plus I will monitor and make sure that everything stays at/near 12.5V. i also carry an emergency portable bank to jump start the engine (worst case).
Jan 7, 2011
5,944
I just replace some old “marine” deep cycle group 27’s for 2) 215 aH golf cart batteries. I am anxious to see how these hold up….I still need to add a starting/backup battery to the system.
good luck on your trip.
Fredct
Sep 21, 2020
86
Oday 28 Westbrook
@Tally Ho After discussing with the captain, here are my orders.
Buy a new deep cycle 27M for the House. Swap it for the new 27M Crank-type that I just installed. Keep the new 27M strater-type on board, just in case (that's plan D). In the fall, remove the existing starter battery and install the new one.
