Hi All,
I finally decided to hook up what I call the 'shore water' feed on my Hunter 41DS after not using it for several years.
It is spraying a decent amount of water around (and not through the faucets
) at the external attachment.
From looking at it a little closer it appears that there is a rubber gasket between the traditional garden hose attachment section and the part built into the boat.
Definitely not a high priority for me (I like to use the water tanks themselves so the water is always fresh there) but would like to keep it functional.
Seems it would be an easy job to disassemble and replace the apparent rubber sleeve but thought I would check in here first before having yet another 'to do' on the boat project list.
Has anybody done maintenance on one of these before?
Thanks in advance, pic attached.
