I just bought my first sailboat, a 1990 Hunter 28. Survey went well but one of the issues identified that would require a haul out to repair was the seacock below the galley sink has a broken valve in the open position. The surveyor mentioned I could remove the sink drain line above the valve and add a new temporary valve to the valve that attaches to the through hole until I can do a haul out and replace the seacock entirely. I figured that meant the top of the seacock is above the water line but I really am not positive. When I tried to remove the very tight fitting hose I saw some water dribbling out so I put the hose clamps back on and stopped. Wondering if this is a good way to repair this or should I wait and haul it out. My experience with working on old boats is when you take something apart you typically break a few new things that you were fixing and since I am putting pressure on a seacock I am a bit uneasy about this seemingly simple patch job. If I plug the thru hull on the underside of the boat am I pretty safe to try and attach a temporary ball valve to the top of the sea cock? Or is that unnecessary? Trying to avoid a haul out now if I can as I need to do a few other things when I do that and was hoping to put that off until the end of the season. I appreciate everyone help. The attached pic is from the survey so the thru hole is one of the 2 circled but not sure which one.
