Playing on the internet I saw a Vetus motorized ball valve which would make life a lot easier. My engine thru hull is under the aft birth and a pain to open and shut. Anyone ever used one? Good or bad idea? I haven’t searched pricing yet.
It’s an interesting idea. Some quick googling suggests they’re north of $600, for example Vetus Motorized Ball Valve 12V - 316SS - 3/4". I’m also no Luddite but I like the idea of an actual mechanical lever that I can close in a pinch for that purpose.
Think out of box.Good or bad idea?
On further digging, I see the valve body is SS (Ball valve made of stainless steel (AISI 316) and it's the motor housing that is aluminum. Sounds good if you've got an unlimited supply of money. Be sure you've got a manual ball valve upstream if something decides to go south with the motorized valve.From the description “aluminum casing, stainless ball”, it sounds like a bad combination.
A motorized stainless steel seacock is an interesting idea. I prefer bronze seacocks of the configurations below. As a former oil refiner engineer I like manual valves for process line-ups and in this application no control valves that would introduce pressure drop and restrict flow and risk failure, and most importantly not in the closed position. I also like to put my hands on the seacock lever to verify valve position. I would also specify bronze vs stainless steel in marine application to mitigate the risk of crevice corrosion, which occurs when there is a localized breakdown of the protective passive layer on an exposed surface corrosion. If I did not install a motorized valve in marine plumbing I would also install manual isolation valves for maintainability..............My engine thru hull is under the aft birth and a pain to open and shut. Anyone ever used one? Good or bad idea?................
Ouch, $1400.00 at Defender. Guess I'll be moving bedding each time.Think out of box.
Keep you standard, hard to reach, valve.
Add the electric one in series.
The Expensive one for Marine service, by Groco. ≈$450
A cheaper one for convenience, with Stainless Steel Body ≈$40
https://www.amazon.com/Motorized-St...7MK96PCGNJR&psc=1&refRID=DTQQXZCNY7MK96PCGNJR
Jim...
The cheaper $40 version might be good for isolating my water tanks rather than removing cushions and kneeling to close one and open the otherThink out of box.
Jim...
Now that idea I like.The cheaper $40 version might be good for isolating my water tanks rather than removing cushions and kneeling to close one and open the other![]()
Another reason I love my C-34... The valve is under the head sink. The ignition key hangs just above it. Grab the key, open the valve. leave the key, close the valve... It IS just that simple...Thank you Frank Butler...
May be mistaken but I believe there are other boats which have seacocks under sinks too.Another reason I love my C-34... The valve is under the head sink. The ignition key hangs just above it. Grab the key, open the valve. leave the key, close the valve... It IS just that simple...Thank you Frank Butler...
I wish, the thru hull is in the middle of the aft birth. There is no other access other than removing all the bedding to gain access. I didn’t think this was a good idea but seeing it’s starting to be available from marine suppliers I figured I’d ask. I always liked exercising my thru hulls and lube them at the beginning of each season. I still think the majority of boats out there leave them open all the time. We forum users represent a small segment of the boating community. We are the DIY‘ers and tend to know everything about our boats. If not we learn when something goes wrong. Often we have a better understanding than our boatyards.Wouldn't it be a lot cheaper and simpler to install a deck access plate as below in the side of the bunk?
