Hi Guys,
I have a leak in the aft. cabin on my 1995 Hunter 35.5 Legend.
The leak is coming from the upper joint between the aft bulkhead and the ceiling where I believe the base (triangular) of the base (circular) of the pedestal is attached to the deck (Photos). I think the leak is coming from one or more of the bolts/screws that attach that base of the base (triangular) of the pedestal. So I believe I need to re-bed the bolts, but I need to know:
How do I get access to the inside of the cover inside the aft. cabin to loosen the nuts?
How is the pedestal attached to the deck, if with bolts how do I get to the nuts?
Thank you.
Thank you.
