Steering Backwards
Sep 24, 2018
3,104
Catalina 30 MKIII Chicago
I've seen a few pics where the wheel is backwards. Is this simply done because there's no place for a pedestal?
LloydB
Jan 15, 2006
902
Macgregor 22 Silverton
Same as a tiller or a car push the top towards the side of the boat that you want to make circles. The more you push or turn the tighter the circles get it works in both forward and reverse. Steering behind rather than backwards I think.
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
More room in the cockpit. Perhaps simpler connection to tiller quadrant - can use direct rack & pinion connection, rather than a chain as freestanding binnacle, which is the reason for the angling of the reverse-mount?
Here's another example from the Truman Show, but that boat trip didn't end well:
Pedestal steering uses cables to turn a quadrant on the rudder post to turn the rudder.
Some boats like the one in the photo use a rack and pinion gear to turn the rudder. There is one other direct drive method, I can't recall at the moment.
4,638
Hunter 46 Point Richmond, CA
Interesting thread on backward steering wheel.
When steering a boat with rack and pinion or worm gear (Thanks @capta for the name) the helmsman stands to the side of the wheel. The spokes on the wheel make it easier to hold onto the wheel and control it. Standing to the side often allows for greater visibility forward since the cabin house and masts will not obstruct sight lines.
capta
Jun 4, 2009
4,877
I actually installed stirrups (simple brass ones on either side of the worm gear casing), and they worked great in heavy weather.
That sounds like something Mike Plant, The Ocean Cowboy would have done. YeeHaw!!! :biggrin:
1,325
Rob Legg RL24 Chain O'Lakes
How do you feel weather helm if you have a worm gear in your steering? Seems wrong on a sailboat.
Oct 2, 2008
3,810
Pearson/ 530 Strafford, NH
Nice reflection, but I disagree with the visibility comments. Most vehicles have the operator in front for visibility or in communication with someone who can see forward.
