Does anyone know the total length of sanitation hose required for C30?
May 19, 2016
127
Catalina 30 Riverside, NJ
Does anyone know the approximate length of sanitation hose required if I wanted to replace it all? I am buying a new head, and would like to replace all the sanitation hoses. Just wondering what the approximate length would be.
I would also like to replace the supply hoses, and increase the diameter of the holding tank vent line, and re-route it to a new bulkhead thru-hull.
Thank you much,
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
You might want to look at this post from the Hunter forum: Sanitation question
TLDR: Measure your particular boat with a sewing tape measure, buy highest quality sanitation hose like Raritan SaniFlex, which will be god-awful expensive so you want an accurate measurement, but add a foot or two to avoid coming up short.
If your vent is through the stanchion, like my Catalina, you may want to replace with a simple mushroom through hull drilled below the rub rail, to improve venting and avoid spiders clogging it up.
Likes: snoopy_
May 19, 2016
127
Parsons,
Funny, I did plan on using a sewing tape to get the exact dimensions. i.e. It's cloth, it bends, it made sense. I was just wondering what the average length and cost would be, I bought the head already, just wondered about additional costs.
I am familiar with many of Peggy's posts, as a result I purchased her book, but I had not read that thread though, so thank you for posting it. It is through Peggy's posting that alerted me to swapping out the vent and yes, running it through a bulkhead thru-hull under the toe rail. I plan on living on this boat for long weekends over the summer and I am trying to address and solve all issues relating to the head.
We will be at a marina and will use their facilities mostly, but the head needs to be functional and odorless!
Thank you,
Jul 7, 2004
8,536
Hunter 30T Cheney, KS
I just ordered a 10' length of 1 1/2" Saniflex from Defender. $117.96 with shipping, tax , dealer prep etc.
Jul 12, 2011
1,165
Also, as I noted previously, don't forget all the "other" lines that run to your waste tank like macerator / sea dump, pump out, etc. that prob use the same hose. @Peggie Hall HeadMistress says you don't have to use sanitation-grade for the vent line.
May 19, 2016
127
Justin,
Thank you very much for the info, it's greatly appreciated.
Parsons,
I don't think I have a macerator, but I would like to use 1" sanitation hose for the vent. I read that vent lines can develop odors too, and sometimes the holding tank can backup eject their contents out the vent.
Thanks,
Dec 2, 1997
9,011
- - LIttle Rock
I don't where you got that idea, 'cuz I'd never say that! What I do say is that it's ok to use the less expensive flex pvc #148 SANITATION hose for the toilet intake line and/or vent line. In fact, it may be the ONLY choice for a "standard" 5/8" vent line, because the premium sanitation hoses are only available in in 1" or 1.5". A #148 vent line will permeate (toilet intake lines do not), but only if waste is allowed to spill out the vent and even then, it takes a while...and fortunately replacing it is inexpensive and is--or should be--a fairly easy job. But if you've upgraded your vent to 1", I'd go with the hose that doesn't permeate.
--Peggie
