I am having to take a lot of strain on the furling line to furl my genoa, more so than in the past.
I found that the furling line had a lot of twist to it and took the twist out. When doing so, I found that the furlex drum (the whole thing) would rotate when I grabbed it and rotated it by hand. See video below. This doesn't seem right but I can't find anything in the manual that says it should or should not rotate. For those with this type of furler, should it rotate or is some kind of shear pin sheared? Any help would be appreciated or if you've a good person or number to call at Sheldon to find out that would be great.
