I believe you nailed it! That looks just like their insignia - and the boat was built in Europe so French hatches make a lot of sense.I think that is from Goiot. It looks very much like the ones on my C&C that I just sent off to a company to have refurbished.
Bingo!! Same question on this thread.I think that is from Goiot. ....................
Just got a quote from Select Plastics for replacing three 36 year old, severely scratched fore deck 20x20 inch Bomar hatch lens (polishing did not remove the scratches) with new heavy duty marine acrylic lens, gasket and seal for $502 each and 6 week lead time. Since the lens are not crazed and the seals do nit leak I just installed new sunbrella hatch covers for a fraction of that cost. Now the hatch scratches are sight unseen.............Now - the task of replacing the lenses............Or contact......Select plastics...... (or live with them as is, at least for the time being...)
It is not inexpensive to have SelectPlastics replace the lens. Last year that was about what I paid for 2 Lewmar hatches with new gaskets and lens. We now have sunbrella covers to protect the lenses when we are not using the boat.Just got a quote from Select Plastics for replacing three 36 year old, severely scratched fore deck 20x20 inch Bomar hatch lens (polishing did not remove the scratches) with new heavy duty marine acrylic lens, gasket and seal for $502 each and 6 week lead time. Since the lens are not crazed and the seals do nit leak I just installed new sunbrella hatch covers for a fraction of that cost. Now the hatch scratches are sight unseen.
Good to know.Just got a quote from Select Plastics for replacing three 36 year old, severely scratched fore deck 20x20 inch Bomar hatch lens (polishing did not remove the scratches) with new heavy duty marine acrylic lens, gasket and seal for $502 each and 6 week lead time. Since the lens are not crazed and the seals do nit leak I just installed new sunbrella hatch covers for a fraction of that cost. Now the hatch scratches are sight unseen.
Smart choice. When you decide you need new lenses, just do it yourself. Acrylic comes in a variety of thicknesses, so you should be able to duplicate what you have. I did mine, and changed over from smoked to translucent white. Still let in a ton of light, but not as much direct sunshine. I also went a bit thicker than the original, just in case someone stepped on a hatch due to unforeseen circumstances.Just got a quote from Select Plastics for replacing three 36 year old, severely scratched fore deck 20x20 inch Bomar hatch lens (polishing did not remove the scratches) with new heavy duty marine acrylic lens, gasket and seal for $502 each and 6 week lead time. Since the lens are not crazed and the seals do nit leak I just installed new sunbrella hatch covers for a fraction of that cost. Now the hatch scratches are sight unseen.
Lewmar hatches have ½" acrylic lens. If you have the time and patience to replace the lens then it is worth the effort. One issue with Lewmar Ocean hatches is the gasket. The lens needs to be removed in order to replace the gasket. My understanding is replacing the gasket is a bit tricky and not one I wanted to learn. Since the gaskets needed to be replaced and the lenses were crazed and clouded, we replaced both.Good to know.
I now know that I don't even have to talk to Select Plastics. Let's see, you have 20" X 20" Bomar hatch lens, how thick is that acrylic? 1/4"? A 24" X 24" X 1/4" clear sheet of cast acrylic from McMaster is about $60.... Of course I'd have to buy the adhesives needed, so that ups that base price a bit. But I can probably do all my hatches for less than the $502 - of course, I'm not paying myself any $'s for my labor... But, I do look at this as my out-of-pocket requirements and then have to figure in when I'll have the time... But these are pretty easy to do...
dj
1/2" certainly ups the price to about $110 per 24X24 piece.Lewmar hatches have ½" acrylic lens. If you have the time and patience to replace the lens then it is worth the effort. One issue with Lewmar Ocean hatches is the gasket. The lens needs to be removed in order to replace the gasket. My understanding is replacing the gasket is a bit tricky and not one I wanted to learn. Since the gaskets needed to be replaced and the lenses were crazed and clouded, we replaced both.
It is much easier to replace the lenses on Bomar hatches. A new lens can be ordered from Bomar that is cut to fit the hatch. Then it is simply a matter of removing the old lens, cleaning up the frame and reinstalling the new lens. The gaskets can be replaced without removing the lens. I did this on my last boat. If I had Bomar hatches on my current boat, I would have done the job myself.
Also check TAP Plastics for either acrylic or polycarbonate sheets. Also check with SelectPlastics for lens material.1/2" certainly ups the price to about $110 per 24X24 piece.
I've likely got Goiot hatches. The seals are fine, and don't have any interference with the lens, at least at this point as far as I could tell. Additionally, on these small lens structures, I prefer the modern formulations of the UV and scratch resistant polycarbonate. I know, I know, the whole acrylic vs polycarbonate "war".... I've used both materials for many years. And if I'm going off-shore and getting clobbered (well, preferably only potentially clobbered) on these hatches by breaking waves, I much prefer the added impact resistance of the polycarbonate. Plus the modern formulations with UV resistance make the polycarbonate much more attractive - in my opinion.
dj
tap plastics is a good source, especially for cast acrylic. I've never seen them carry UV, Scratch resistant polycarbonate however. I just looked on their website now also, and did not see it - I only see the scratch resistant variety. I might give them a call though. Thanks for the tip.Also check TAP Plastics for either acrylic or polycarbonate sheets. Also check with SelectPlastics for lens material.
