Last year, we moved up to a Beneteau 393 and it seems that we have a singing prop. It is quite loud and takes some of the enjoyment out of gliding along with only the sound of water and wind. I brought this up with a Beneteau forum and since I got some inconclusive answers, I thought I'd root around here to see what comes up. My search through the forums here yields similar results but I thought I'd try again with a new post on the topic. I'm almost 100% certain that the singing prop is the issue but I'll lay out my case. The boat makes a very pronounced hum similar to a wine glass rim when rubbed with a wet finger. It only appears at certain RPM, and it doesn't matter if the boat is under power or sailing with the transmission in neutral (Yanmar says not to sail in reverse). The boat has a three blade fixed prop and I've heard some suggest filing an "anti-singing edge" on the forward edge of the prop blade. This "fix" seems pretty contentious as many people argue that this will make the prop unbalanced and will do more harm than good. More research on the subject shows the edge should be filed to a rather sharp edge 40-45 degrees. Others have said the edge of the prop should be squared off to prevent singing so there is quite a conflict in blade edge geometry.
I'm considering buying a feathering or folding prop because this will surely remedy the situation but I thought before I invest such a heavy amount in a new prop, why not see if I can get a relatively conclusive answer to whether or not the anti-singing edge is worth a shot.
Thoughts?
Thoughts?
