I was just commenting on the cost of those sails compared to my low budget cruising sails. One of those sails is probably worth more than my boat.Not sure it is all that much more expensive in the long run
You got that right. Certainly my boat. But if you are racing to win the America's Cup for the pride and glory of your Patron. Then the using of his money is no hinderance to the result desired.One of those sails is probably worth more than my boat.
Probably all the above. I think the AC75s have a driver, a mainsail trimmer, jib trimmer, tactician and several guys to crank the hydraulics up. I would imagine any one of those trimmers has forgotten more about trim than I will every know.Isn't like putting flaps and slats down on an airplane. More lift at slower speed (greater camber) then bring them up to go faster?
I have been wondering how they control the camber. You can see lots of depth in the sail when they are trying to get up on the foils and then they really flatten them out at speed. Since some of them don't have a boom for outhaul purposes I wonder how they are doing this?Isn't like putting flaps and slats down on an airplane. More lift at slower speed (greater camber) then bring them up to go faster?
There is an internal framework between the 2 layers of the mainsail. Unlike the mainsails we all use, that have one piece of fabric, the AC 70 mainsails have 2 pieces with the framework between them. This allows the trimmers to trim both sides of the mainsail.I have been wondering how they control the camber. You can see lots of depth in the sail when they are trying to get up on the foils and then they really flatten them out at speed. Since some of them don't have a boom for outhaul purposes I wonder how they are doing this?
I saw a quick description somewhere on line. The rules allow the dual mainsails and each team seems to have its own solution. All in all, it is a clever idea that none of us will ever be able to afford.Closely guarded secret by the various race teams on “how” they do it no doubt. Quite a little mess of spaghetti coming out of the rear of the sail(s) - the “magic” is behind the curtain
View attachment 188330View attachment 188331
Just a wild guess but if you had line attached to both ends of a batten you could adjust the amount of “bend” by changing the tension.
Not sure about the affordability thing - kinda spendy nowI saw a quick description somewhere on line. The rules allow the dual mainsails and each team seems to have its own solution. All in all, it is a clever idea that none of us will ever be able to afford.
The theory is by altering the leeward side as well as what windward side of the sail there is increased efficiency of the foil. Keeping the leeward side flat with a full windward side removes some turbulence on the leeward side. Much like an airplane wing, flat on the bottom, curved on top.
(no doubt that description will generate some DOM thoughts.)
Dark magic!
Well, the color of the sails would suggest dark magic.Would "wind magic" be more to your taste?
There has been a push in the past few years in the elite racing world to lower costs in order to keep and attract sponsors. Using a crane to remove the mast and wing sail every day gets expensive quick.@DArcy posted a link near the beginning of the thread that might answer some of your questions but I think the main reason they have gone to the double skin sail is that it is “hoistable” but can approach or perhaps exceed the efficiency of the hard wing “sails” of the earlier classes.
It also raises all kinds of renewed interest![]()
