Square sail
Jun 15, 2020
38
Laguna 26 Laguna 26 Lake Washington
I am in the process of converting my Laguna 26 into a square-rigged vessel. My slip neighbor pointed out it could be considered a “gaff-rigged spinnaker” but I want to pretend I’m in a Patrick O’Brian novel, so I’m sticking with “square rigged”. If you think this wacky idea might be entertaining to read about, here is the blog:
Square rigged sailboat blog
11,386
Was skeptical, but I read quite of bit of your blog. Much more than I expected.
This is the kind of madness that I can really get behind. Carry on!
Likes: jon hansen
I've never really thought much about the physics of how square rigged boats work... but I have noticed that they can reach. I have done a little reading on the Viking long boats and know that they "tack" the windward side of the sail's foot someplace near the bow and then sheet the leeward clew.
In your research, have your run into any discussion about reaching with a square rig? Can you also rig a traditional genoa and have that deployed with your square rig on a reach?
I'm curious.
Nov 8, 2010
11,386
I'm curious.
A well designed square rigger can do about 60 degrees to the wind. So its technically going upwind, but nothing like modern sloops can do. Downwind it suffers vs a actual spinnaker as well.
A fun experiment, but there is a reason we've moved on from them.
Likes: rgranger
@rgranger, came across this and thought of you.
2019 Festival Boats | Port Townsend Wooden Boat Festival
Gyrfalcon
For Sale
Home Port: Port Orchard, WA
Year Built: 1995
LOA: 22'5"
Owner: Jeffery Miller
Designer: Oslo Trebatbyggeri
Design: Kobberklinket
Type: Sloop
This boat was hand crafted in Norway and shipped to a Norwegian Merchant Marine living in Seattle with his American wife. It is constructed primarily of an oak frame and pine lap boards, and has a full length keel to allow sailing in shallow water. The mast supports a traditional main sail and jib, or the boat can be rigged with a red and white square sail reminiscent of the early Viking ships. Two systems can be used to steer the boat, a traditional rear rudder, or a side paddle which can be fixed to the starboard side. This boat is strictly a wind driven vessel and was never designed to be outfitted with a motor. There is a set of oar locks and 12′ oars should you lose your breeze!
-Will (Dragonfly)
Feb 27, 2004
172
Hunter 335 North East, MD
Wow what a fun thing- I read your blog (or tried as I really couldn't follow the math) - I actually have sailed on a square-rigged ship for the last 10 years (historical reproduction)- a couple of sail controls I didn't notice were bowlines and tacks. Bowlines would run from the leech of the sail and pull the windward side of the sail forward (Jack Aubrey's sailing on a bowline). This is done when the yard is braced and you were trying to sail to windward- when yard is squared bowlines are slack. The tack is attached to the corner or clew of the sail and it also runs forward- again when braced the weather tack is hauled forward and the lee sheet is hauled aft. When sailing square, no tacks are used. I am partially convinced that the bowsprit on square rigged ships was a way to bring these lines forward.
38
Thanks for the comment and explanation. I use the square sail for downwind sailing only, so the sheets only run aft; I haven’t found a need for bowlines and tacks. I rotate the yard-spar (and thus the head of the sail) about the yaw axis using the braces, and I can rotate the foot of the sail by pulling on the appropriate foreguy, which pulls that crossjack (aka whisker pole) forward, thus moving the associated lower corner of the sail (is it a tack? is it a clew? I have no idea!!) forward as well. When sailing upwind, I use the mainsail and genoa just like a regular fore-and-aft rigged sloop...or I just turn on the motor...gasp! A sailing heretic!
Do you have any pictures or weblinks you can pass along for the square rigged vessel you’ve been sailing? I’m most curious! Thanks again for the comment.
capta
Jun 4, 2009
4,986
The Vikings had these great inventions called oars and I bet dollars to donuts they never even tried to sail to windward. Heeling an open boat isn't the best idea in any seaway.
Likes: jon hansen
Feb 27, 2004
172
LagunaJay- the square rigged ship I sail on is the Kalmar Nyckel, the tall ship of Delaware. We are a reproduction of the vessel that founded the colony of New Sweden (basically Delaware, southern PA and southern NJ) in 1638. Think Mayflower of Delaware although we made 4 round trip crossings and the Mayflower just one. There are bunch of videos on you tube and Vimeo - here is one we made for the school kids of Delaware about sailing
while further information can be found on our website www.kalmarnyckel.org. We are an all-volunteer crew with the captain and mates being paid. We do crew trainings several times a year (although the pandemic has temporarily curtailed that) and we get folks from all over the states and world doing the training.
Jun 15, 2020
38
Wow, what a super cool vessel and awesome website! I have sailed on the Lady Washington but she’s only a two-masted brig; if I’m ever back east I know where I’ll be heading. Hope to see you aboard someday!
Likes: nveater
Jun 15, 2020
38
I have never seen a mast mounted at the end of the bowsprit. Those Dutch ... very clever!
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
I had the privilege of volunteering at Jamestown Settlement in Virginia for a few years. During the off season I participated in maintenance work on the Susan Constant, Godspeed, and Discovery. I had the opportunity to sail on Susan Constant and Discovery in Chesapeake Bay and to help move Susan to dry dock for routine bottom maintenance.
I enjoyed the work immensely, and got a tremendous education as a member of a crew sailing square rigged 17th century craft. Its not as easy as sailing my Bene.
Sadly, had to give it up due life changes and a knee replacement.
Feb 27, 2004
172
It's a sprit topsail an affectation which died out about 1700- if you look at paintings of ships from the 1600s you can often see them
