Hello to Peggy Hall and T J Furstenau and other Hunter Owners.
Regarding Aluminum Waste Holding Tanks
Peggy was correct!!!! .... back in August 2020, when she said that if you find corrosion on an aluminum waste tank that you can see, it will not be the first and there will be other areas that you cannot see ! Well, yesterday I had the marina service department help me remove my 25 gallon tank. We had to use the Sawzall to cut off the top vent bib and the side "feet", but it came out of the tight access in the aft cabin on my Legend 37.5 and guess what? The bottom was corroding like a sun of a b____!. It looked like it had a disease.... there was so much corrosion. We managed to get tank out of the aft cabin by turning it sideways to go thru the aft cabin door and up the companionway and the marina people took it away.
I am ordering a new plastic tank from Ronco, and new sanitary lines and 3/4 inch vent line.
Just wanted to thank you guys for your invaluable advice and to pass it on to others who are about to undertake this project, unless of course, I am the very last Hunter Owner in the country to finally remove their aluminum tank!
