Winter Cover for mast up boats?
Sep 27, 2008
181
Hunter 33 Danversport, MA
Anyone have some cost effective advice on a winter cover?
In New England. Heavy snow....
At the moment, contemplating the conduit method (practical sailor).
Open to advice....
Thanks in advance
7,668
Alden 50 Sarasota, Florida
Two options:
1. Boom tent tied to the toe rails to cover the cockpit and spinnaker pole serving same purpose forward, and
2. Move to Florida.
After years doing the former, we decided the second option was easier
Sep 27, 2008
181
Why Florida? Are winter covers cheaper there???
OK I am kidding too. Plan B is not a bad plan
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
You might find this article helpful.
custom boat covers:
Catalina 34 Casco Bay
I'm in Maine.. WE get just a tad of snow... Did the PVC gig years ago. The PVC will fracture at the joints with wind and snow load. Did a Shelter Logic building for years. Worked great until the follow on boat was too big ( lifeline stanchions wouldn't clear the arc). The most cost effective was building a ridge pole framework of 2X4s in the bow, midship and stern. It supported a 2x4 ridge board that was joined together with plywood plates at the joints. Strapping was clamped on the stanchions inboard and outboard long enough to apply a top plate that rested on the stanchion top, thereafter no need for the clamps.. Then strapping was mitered to the ridge and doubled up stanchion strapping rails and screwed in place. ALL mitered pieces marked P or S and numbered. 40' poly tarp over the framework and secured. Not an advocate of leaving the mast up all winter, so fitted covers ( one came with this boat) are not an option.
Jan 7, 2011
5,906
Oday 322 East Chicago, IN
In Chicago area...so a bit snowy here...
this cover has worked well for about 5 years so far...
I got this one from “The Canvas Store”.
Likes: sail sfbay
Jul 19, 2013
390
Pearson 31-2 Boston
Start with
MY perspective is that more plastic tarp covers fail than not, usually due to ripping from weight of accumulated ice balls. Any sagging in the cover and it will fail. To avoid sagging, the plastic cover needs a lot of pitch and to be absolutely tight as a drum.
TomY
Alden Forum Moderator
Jun 22, 2004
2,769
This works for me: 2X6" high ridge supported by 3 A frames and a 30' X 50' plastic tarp.
Mast up, I'd go shrinkwrap and hope you could recycle it.
I live nearby and can keep an eye on it. I've never lost a tarp in over 10 winters on the coast of Maine but I think I'm the exception. :) It helps me in the spring allowing some work to be done in poor weather. It keeps the boat bone dry and well ventilated (I leave all the hatches open below and open a small vent on each end).
The only cover that has no compromises, is a building.
Likes: sail sfbay
ToddS
Sep 11, 2017
248
Beneteau 373 Cape Cod
That looks to have good pitch for discarding snowfall, but having the cover underneath the stand bases would give me a big cause for pause, although it is difficult to explain exactly why...same feeling if my boat was on either side...
My boat yard has a strict "nothing attaches to the stands" policy... can't tie a tarp to them... nothing... understandably. I'm not sure if clamping the tarp between the stand and the hull technically counts as "attaches to"... but I wouldn't do that.
TomY
Jun 22, 2004
2,769
I'd agree, if I haven't been doing it for so long. :)
I tighten the poppits and capture the tarp against the hull. The stands are chained together in 3 pairs. Then I lash the tarp grommits from side to side under the keel.
Each end is sealed with a 4 - 6' 2x4 rolled up inside the excess tarp material, then another is place on the outside of the wrapped 2x, and screwed into it to sandwich - secure the ends.
I rarely loose a single grommet over the winter which is unheard of with plastic tarps.
I've never had the stands loosen due to the tarp. And I check all the stands in the yard and mine are the ones that need the least adjusting. We get a lot of wind right on the waters edge. Go figure.
Jun 14, 2010
2,466
Not difficult at all... more likely to slip. Good eye.
(PS - not being critical of Tom. Utmost respect. Sometimes it just helps to have another eye on something.)
The problem I had with tarps was that if I got one long enough to cover the boat from stem to stern, it was too wide for the ends of the boat causing me to use some wonky attachment system. This was true for 5 or so boats I had. One year I got a tarp for my dory. It had the usual problem. So I tied the grommets to the trailer and folded the tarp excess along the ridge pole. I then taped the seam and my wife made some fancy seam from her sewing background. It was pretty easy for her other than handling the tarp. So in the end it fit the boat pretty snugly and I replaced the ties with shock cord. The shock cord didn't make the whole winter, due to winds and some tree branches, and there was substantial water in the boat. Good plan - bad execution. Now you could probably just tape the seam. It helps if you don't have to leave the boat under trees.
When I tar
ped my boat I used these.. Slick as all get out.. A star shaped disc is placed in a gather of tarp where YOU want purchase. Then the pinch ring goes over the gather and secures the tarp.
Jun 14, 2010
2,466
When I tarView attachment 185829ped my boat I used these.. Slick as all get out.. A star shaped disc is placed in a gather of tarp where YOU want purchase. Then the pinch ring goes over the gather and secures the tarp.
Technology as old as the garter belt ;)
You might think it’s new if you grew up in the pantyhose era. :facepalm:
