M-25 oil pan hose
Jul 20, 2020
9
Catalina C-30 Noank
Just moved up to the C-30 so happy! is there a pump that comes with a suction hose connection that will screw onto the M-25 hose nipple? If not suggestions on what to purchase.
thank you
May 7, 2011
281
C - 30 # 3573 Lake NormanNC formerly Bflo NY
AE
Are you SURE you have an M-25? And not an M-25XP? The M-25 didn't come with a hose.
Do you have the manuals? Boat owners, engine ops, engine parts, engine technical?
The hose fitting on the M-25XPA is 1/4" NPT, but that engine was by Westerbke (after it bought Univeral Medalist.) So I can't verify the size used on the earlier engine. It MAY be 1/4" but the XPA hose is a different part # so who knows.
For my money, if I had the drain hose I would put a female quick-connect on the end and a male end on my pump hose (or on a barbed fitting so I could use a throw-away hose) so I didn't need to mess with the fitting anymore. I use a 12/ impeller pump that I suck thru the dipstick tube (or "guide, oil" as Kubota calls it.) It is a multi=purpose pump I have set up for many uses on the boat. I bought a Worst Marine 12v pump and it lasted 2 seasons. I have used this one for 25 years.
It really helps if you put your boat, hull, keel, engine info ( mk-?, yr? tr/sr? bs? fk/sk/wk? hull #? etc.) in your profile or signature to help us help you.
Cheers, Ken
My M25 has one, don't know if the PO put it on, but doubt it, he wasn't that kinda guy. It has a male threaded fitting on it.
I just found a female fitting to match and put it on the hose to my hand pump to change the oil.
May 7, 2011
281
Interesting... unless AE has a very late mk-I but kids haven’t see a hose on the ‘30s m25. I think cty changed to the yanmar somewhere in that timeframe. Of course I do know a few m25 owners who added a hose when they replaced engine mounts. I’m wagering 10:1 odds on a mis ID of the engine. We just had a member who got two different engines ID’d by two different surveyors. Ha!
Jul 20, 2020
9
Catalina C-30 Noank
HI Guy's,
Your correct it is the M-25XP 1989 C-30 #5355 I'm in contact with the previous owner for guidance.
Thank you for taking the time.
Stay safe,
John
May 7, 2011
281
John
If interested I could dig out the info on my multi-tasking pump for you. Why not just unscrew the plug on the drain hose and take it to a hardware store** or big box to verify whether it’s 1/4” npt?
Harbor Freight and offers have air line quick connects that could be put on the hose to make it easy peasy to attach a pump to. There’s more compact mini Colder brand QCs that I use for other applications (if interested I could send you info.)
** if you can find one, these are the threatened species of neighborhood retail establishments that used to stock everything under the sun where you’d be greeted by a friendly helpful owner who couldn’t do enough to help you out the door with what you needed.
Catalina 34 Casco Bay
My M25 has a oil sump hose. My 12 on an older boat/engine also had the oil sump hose.
Dec 23, 2010
8
catilina 36 abacos, bahamas
I recently discovered that hose in the bilge on my new to me ‘90 - 30 ‘ Cat - that hose scars the hell out of me - I can only imagine something going wrong and losing oil - I’ll replace it on the next oil change with a oil pan plug - no hose -
