Jib sheet jams
May 21, 2014
129
Hunter H44 Toronto
Does anyone have a solution for the jib sheet catching at the bottom of the inboard shroud where the shroud fitting pins to the deck SS plate? See photo.
You could wrap it. Maybe with some amalgamating tape or electric tape.
JRacer
Aug 9, 2011
1,409
Short piece of PVC pipe with a large enough inside diameter to fit over the chainplate perhaps.
JRacer
Aug 9, 2011
1,409
What if you cut the tube so that it was a half pipe below the chrome strip and a full pipe above? Then the half pipe would extend down to cover the chainplate and the full tube could rest on the deck above the chrome piece.
JRacer
Aug 9, 2011
1,409
Or, is there any gap between the shroud/chainplate and that chrome strip? If so, you could use a smaller diameter PVC pipe, large enough to cover the shroud and its turnbuckle and cut a slot in its bottom end in a width sufficient to slip over the chanplate.
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
A crazy idea might be to fab a "plastic" washer with a center hole the size of the clevis pin, the thickness of the opening, and a diameter the would extend to the mouth of the U-shaped fitting. In theory the washer should fill the gap and spin with the sheet. Just a theory
Sep 20, 2006
2,955
Looks like you can get behind the chainplate? I would try criss crossing almagamting tape over and under the hand rail and back over the chainplate.
Jun 1, 2004
8,361
JSG's and Justin_NA's spacer is the best solution. Regular SS washers would work also.
Aug 13, 2012
533
Catalina 270 Ottawa
I'd suggest to use the rigging tape (amalgamating tape) (almost regardless if you add the washer or a pipe over it). Your picture does not show what you use for the cotter pin, but i have seen a sheet pull the split ring out of the clevis pin. Nothing happened, because the clevis pin was under a load, so it did not fall out, but it could happen.
... Nothing happened, because the clevis pin was under a load, so it did not fall out, but it could happen.
:yikes:
If you hadn't noticed, went over to the other tack.. could have been a bad day.
