Hunter 170 furling Jib problem
Aug 1, 2010
2
Hunter 170 NJ
Last week a strong NW wind blew open my furling jib and shredded the sail. Am thinking of replacing the furling jib with a non furling jib. Anyone have experience with doing that? Thanks DF Cape Cod
A hanked on jib only requires that you take the roller furler off of your forestay.
If you go that route, I recommend a simple down haul system to tame your jib if a stiff breeze pops up. Lead the down haul back to the cockpit then you can tame your jib without going forward. If you keep the sheet tight and drop the jib using the down haul, the jib will flake nicely along a gunwale and sit there until you have time to deal with it.
Likes: Hunter216
Sep 22, 2018
1,869
Hunter 216 Kingston
As you know the original design for the 170 has the forestay integrated into the jib. Same configuration as my 216. I find the furler makes quick work of handling the jib from the centre of the boat, where a hank on will require you to be at the bow. Having some turns of the jib sheets around the furled sail along with a sail tie is good practice but if the wind is strong enough I suppose that might still fail.
I guess you could potentially salvage the forestay from your damaged sail to eliminate the need to buy a new one. Perhaps ask @Dave Groshong here at SBO if he can source a hank on if you decide to go that route, I know he could help you with a new sail of the original design.
Likes: rgranger
-na -NA Anywhere USA
try this forum store as it is to Hunter specs. Dave Groshong can help you. Owner is former Hunter employee who has all the build parts.
Apr 16, 2017
841
Federation NCC-1701 Riverside
For safety and eas of sailing I strongly suggested the furling jib. Everyone concurred with the suggestion
What is the safety of a furling jib? Ive seen the flying scots sail in to the docks and drop them jibs rright away
I am not sure what you are getting at. I will only say the more you learn you gain experience and at some point with experience for example sail up to the dock with sail down or furled in
JerryA
Oct 17, 2004
550
Hunter Hunter 170 Sandusky Bay, Lake Erie
Having owned a H170, my vote is to keep the furler. It's not designed for easy access to the bow. Just my $0.02.
