I'm new to my 1982 Hunter 33. I discovered that the chain was disconnected from the sprocket inside the Edson steering console. After loosening the cables on the pulley attached to the rudder under the deck, I was able to re-attach the chain at the mid-point/neutral steering position. However, I discovered that when I turn the wheel fully, there is no stop to the rudder and I wind up pulling the cable over the sprocket which disconnects the steering.
Question -- where are there mechanical rudder stops (assuming my logic is correct)? Is there a schematic that anyone can point me toward?
Thanks, Bill
Thanks, Bill
