Propeller for a Hunter 41DS (2005) with engine Yanmar 3JH4E
Dec 31, 2019
2
Hunter 41 DS Gouvia Marina / Corfu / Greece
What type of propeller is the right one for this boat ?
Anyone in this forum with the same constellation ?
Pierrot
Oct 29, 2016
1,929
Hunter 41 DS Port Huron
I believe your engine is a 4JH4E, our Sapphire has a 3 bladed 18 x 12 Flex-O-Fold prop
Dec 31, 2019
2
Thx for the reply, but...
No no, is a 3JH4E, 40hp, 29.6Kw
Pierrot
Apr 11, 2010
998
Hunter 38 Whitehall MI
I think if you do a search in the archives you will find that there are as many favorite props as there are boats and boat owners. The question surfaces periodically and to much amazement the same listing Of favorites starts all over again :)
my 38 has the same 40 HP engine you have. When I decided I wanted a feathering prop I called the dealer I bought it from and he told me the brand he used Most frequently and had good results with. I called that company and told them boat and engine information and the recommended prop size and pitch.
I think you will find that most manufacturers of props will have a good data base to Recommend from
Likes: sail sfbay
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
What type of propeller is the right one for this boat ?..........
Ditto quadrille38 ............depends what type of propeller type (fixed blade, folding, feathering) and how much you are willing to spend. You can do a search on this site for propeller recommendations. Once you select a propeller then go to the manufacturer/dealer and they will provide a quote for one sized specifically for your boat and motor. I installed a 3 bladed fixed propeller on my Hunter 31, 386 and now 46 for cost effectiveness and maneuverability.
You might find this article entitled "Understanding Your Sailboat Propellers" Helpful:
Feb 10, 2017
305
Hunter 41 Progreso
I have the same sailboat and same engine, with a clean bottom in flat water i can do at 2200 rpm 5.7 knots, if you do the same you have the same prop as i do. Thats the factory one. In my next hail out i am going to change the prop with a 3 blade that will not fold but set in a neutral position and i will increase 1 inch the pich
senang
Oct 21, 2009
318
hunter 38 Monaco
On our 2005 H38 with the same 3JH4E engine we have this fixed propellor installed by Hunter:
Thank you for your interest in Michigan Wheel propellers. This e-mail is in regards to the inquiry you sent to our website. The complete characteristics for your propeller are as follows:
17" diameter, 12" pitch, Right Hand Michigan Dyna-Jet with a 1.25" SAE Bore made of Bronze
Thanks again for your interest in Michigan Wheel. If you have anymore questions let me know, thanks.
Likes: sail sfbay
Jul 6, 2017
158
Hunter H 41DS Hampton, VA
We love our Max Prop. Three blade. Reverses great. Adjustable pitch.
Nov 14, 2016
36
Hunter 386 QCYC
Hi Tim,
I am considering replacing my 3-blade fixed prop with a used feathering EWOL stainless prop, but I am stuck on the size I ought to get. What size is your blade in which you have such happiness.
Thanks,
Hamish
