So theres that other guy on here, really I think it would be fine if he wanted to come practice on my boat but it hasn't happened yet. Soo I guess I just have to start my own thread with stuff Im forced to do myself
My goal here is to make my Hunter a solid blue water boat and that means some modifications. I completely believe that the hull and rigging are more than tough enough but I believe the Hunter is lacking in some other fairly important areas. This stems from some of my personal experience but in particular from something I read in a book about heavy weather sailing.
In one part of the book the author interviews a couple who have had the bad luck to sail through not just one but two hurricanes. At some point the author asks them what they would do differently if anything and the answer was "wear motorcycle helmets"
With that in mind,
everything in the interior needs to fasten down. That ice box lid in the kitchen is a 10 pound missile. The way the current shelving in the salon is laid out there is just not enough cabinetry room to store dangerous flying items, there is also no good handhold on the salon roof ( is that even the right word ) nor are there good handholds at waist level.
Hunter definitely saved some building dollars on creating a very open central area but that is not going to work for what I desire. The big job on the list is going to be moving the top shelf that runs the length of the salon on either side in towards the center line so that basically the sliding doors will now be parallel with the mast as opposed to their current "laid back" style.
However before that happens we have to deal with the fore peak and ( grr ) the Yanmar. I have to agree with 757Captain that a 10 gallon holding tank is ridiculously dumb, Its so tiny that I have actually removed the head from the forward head and its main purpose at the moment is a hanging locker.
Not sure exactly what I'll do there yet tomorrow will play a big part. For a while now I've had mineral deposits building up in the tank. A while back I took off the fill gauge and peeked inside as best I could. Its like a mini crystal caverns in there, I was going to sell tickets but when the boat bounces around to much sometimes bits a pieces of the stalagmites break off and head for the feed line for the fresh water system, which I worked around by taking some stainless mesh and inserting it up from the main feed fitting but really I need to cut a giant hole in the tank so I can clean it out. Already have a giant inspection cover waiting for installation.
Before this project gets under way I really wanted to send some engine oil off for analysis just so I can get a feel for what needs to be done there if anything. This requires getting the oil warm so I can suck it out of the dipstick tube, which requires starting the motor. So I go to turn the A B switch and nothing happens and it feels lose. Crap the (g)west marine battery switch that was installed somewhere before my time went pop. Not in an electrical way but the plastic housing that its in is so ******* cheap that the pressure of the spring which exerts force on the contact plate managed to push through the plastic... WTF? ( mind you this is not a switch that is getting baked in the sun all day, its inside under the main berth, safely protected from the elements. )
Anyhow this was todays eventual victory and painful chore. I went to the local above mentioned marine store and got a much better replacement. Unfortunately the switch diameter was slightly smaller than the currently drilled hole. While I could have mounted it as such it would have been ugly, poor work and not bristol in any form, I really didnt want to fabricate anything, especially not for this job so I journeyed off to the Lowes and just started looking at pieces. the guy in the plumbing department ( he deserves a raise ) listened to me for a minute, broke out his tape measure, and said "A Halo will work perfectly, go to the lighting department" 5 minutes later there it is, the ring which is used to hide the hole for the cheap ceiling drop lighting so common in buildings today.
Photo time!!
How the hell this little project consumed half a day I'll never know but at least I have something to start my thread on here with!!
Also, for those of you observant enough to notice, Yes that is an actual official Yanmar service manual and today I digitized the entire thing to pdf. ( so much easier to look at your phone when laying on the floor in the main head vs the manual ) If anyone can direct me to a place to share files on this site and if there is any interest let me know.
Its amazing that I have resorted to this long diatribe to replace the beer I should be drinking since the bars are closed...
Now off to ask the 757Captain some questions.
Cheers,
With that in mind,
Photo time!!
Cheers,
