- Oct 22, 2014
- 24,623
How many times do we hear the question: Can I sail this boat around Newfoundland? Across The Atlantic? To Antartica?
Ok maybe that is a bit over the top, but we hear the question regularly from inexperienced sailors wanting to join the fraternity of cruising adventurers. They see a video, or read a story and they feel the urge to explore. Then the reality of being 20 miles off shore (in reality 20 or 1000 is all about the same in a boat), the wind is starting to strengthen, the CG is broadcasting weather warnings and the once calm ocean waters are beginning to look angry, that is when the doubts about ones boat start to creep into the thinking of most sailors. Am I prepared? Did those guys at SBO give me good info about the boat I bought?
Reading Practical Sailor this morning I was struck by the obvious.
It is a good read. The above paragraph gets right to the point. Boat design is based on the "Vessels mission".
If you do not understand the waters you believe you will be sailing, then boat selection is if not impossible, at the least, a random crap shoot.
We often approach boat buying like we do car purchases. We all know the interstates are pretty much the same so most cars meet the design expectations. If we are planning to drive off road we don't start looking at the Lamborghini dealership for a vehicle. Not all waters are the same. I believe your boat purchase should start with the waterscape and how you plan to explore it.
When you bought your boat what were the triggers that caused you to pull out your checkbook?
Has your purchase lived up to the dream you imagined? Have you had to alter the dream? Or the boat to adjust to the dream?
"From the earliest days of boatbuilding, there were appropriate scantlings for inshore light-duty craft and higher scantlings for ocean-going vessels enduring more arduous conditions. This habit of designing and building to the demand of a vessels mission continues today, and its no surprise that an around-the-world raceboat, which must endure bone-jarring slamming loads, incorporates structural details that are alien to run-of-the-mill sailboats at local boat shows. A crew preparing to wander down the Intracoastal Waterway has no need for a hull and deck thats fortified to endure the torment of the Roaring Forties, but that’s no excuse for shortcuts in critical load-bearing areas." Rethinking Sailboat Structure New designs, construction techniques are reshaping our hulls. Published: January 20, 2015Updated: July 31, 2020
